i have a weird issue in my ladies linux/windows system where the DvdRom won't mount and it will not read anything in the optical drive. I have found a command to use in the terminal, but have not gotten success yet.
mount /dev/sr0 /mnt/cdrom
is what i found as an example, but it keeps telling me: can't find /mnt/sr0 in /etc/fstab or /etc/mtab
or if I type it a bit different: only root can do that
my question is, anyone familiar with Linux Ubuntu know the command to mount the DvdRom? i think it is called /dev/sr0.
i have no knowledge of how to work linux, just have luck with entering commands.
also, it is having an issue recognizing the sound card, it worked for a while, but today, things went bad( i did disable the on board audio!)
thanks for your time and happy holidays....
