Mixing Mem kits
stone
Ive got a TWINX1024-3200C2 PC-3200 1GB Kit 2-3-3-6 184pin DIMM already installed and just bought a OCZ EL DDR PC-3200 / 400MHz / Platinum / Dual Channel 2x1GB.
Anyone knows if i can mix the two mems(as long as each remain on their proper channel) or should i remove the corsair and put the OCZ only?
I just installed the ram,are those setting ok
In CPU-Z:
Clock : 200mhz
Running 2-3-3-6/2T
