Mining in different PCs
Stoly
I just got a GTX1070Ti and I already have a GTX1070. The 1070 is mining on my PC at the office and I want to mine with the Ti at home.
Can I just copy the settings from the claymore miner? Or do I have to make a new wallet.
You can copy the settings.
well kinda!
commonly pools have username = < wallet address > but if you did username = <wallet address>.worker name than you need to change the worker name. everything else may remind the same though I recommend you change the power and locks between the cards
well kinda!
Most of the pools I've mined to just use the .worker name part for statistics tracking. It's helpful for the miner to keep tabs on his systems, but not really required to mine. Of course I'm sure there's pools out there that do expect each system to be uniquely identified.
my XP is that if you have two workers with the same worker name (as in you reference username = <wallet>.worker name) it will cause issues where 2+ miners just using username = <wallet> matters not. but im new (ish) and could totes be wrong.
I have up to 5 PCs mining to MinningPoolHub, then some of those have mixed video cards mining different coins from each other plus cpu's. I just name each card/machine/cpu combination as a different worker and it all works. So I could have over 10 workers on the same pool mining the same or all different stuff at the same time using autoexchange or coin explicit to a separate wallet. Anyways MPH is great if you have a diverse mining topology and want to mine different coins to different wallets or one wallet via autoexchange for selected coins.
