[+Duracell-]
- Jun 8, 2004
Hopefully someone can help me here. I have this block of code (description will follow below it):
The Message object contains 3 member variables: String date, String time, boolean tc.
date should be no larger than 10 bytes (yyyy-mm-dd)
time should be no larger than 4 bytes (hhmm)
Channel contains only one member variable:
HashMap<String, ArrayList<Message>>
Simple walkthrough: First, this block checks to see if there is a log file with IFX in the name. If there is, open it up and start reading it. It'll attempt to match lines with the regex pattern above. If it does find a match, it'll extract the information, create a Message object, and store that Message in a Channel container.
The files are 260-300MB in size, and the program at its current state reads one file in about 2 minutes. The problem is when I read even two 260MB files, I get over 500MB of memory usage. It should never be this much, I think. I read in about 550,000 Message objects, so 550,000 x 16 bytes = ~8.5MB in memory. Even if we multiply that by 10 to account for overhead, it should still be only <100MB of usage.
Am I missing anything here? Is Java overhead really that horrible?
This is Java 6, btw.
Is there any place where I can forcefully deallocate objects in the code? And if not, what are ways I can optimize my memory usage?
Code:
if (log.toString().contains("IFX"))
Date startTime, stopTime;
long timer = 0;
int msgCount = 0;
String date, time, msg, svc;
String[] timeTemp;
// Regex to see if the line matches what we need.
Pattern pattern = Pattern.compile("(\\d{4}-\\d{2}-\\d{2})[ ](\\d{2}:\\d{2}:\\d{2}\\.\\d{3}).*context=MQListener-[0-9]*:(.*?),.*clientName=(.*?),.*");
Matcher matcher;
String line = "";
startTime = new Date();
BufferedReader reader = new BufferedReader( new FileReader(log));
while ( (line = reader.readLine()) != null )
matcher = pattern.matcher(line);
if ( matcher.find())
// Extract information from line
date = matcher.group(1);
timeTemp = matcher.group(2).split(":");
time = timeTemp[0]+timeTemp[1];
msg = matcher.group(3);
svc = matcher.group(4);
// If the channel does not exist in our hashmap yet, add
// the channel to the hashmap.
if (!(channels.containsKey(svc)))
System.out.printf("New Channel found: %s\n", svc);
channels.put(svc, new Channel());
// Add the message to the channel
channels.get(svc).addMessage( new Message( date, time, false), msg );
matcher.reset();
stopTime = new Date();
timer = stopTime.getTime() - startTime.getTime();
System.out.printf("Ran in %d milliseconds\nMessages counted: %d\n", timer, msgCount);
reader.close();
