CrazyDemon
- Feb 16, 2001
Hey everyone,
It seems that time for upgrading has come yet again, and this time it's a Car-PC
I plan to use my old Dual celeron 500mhz pc in a car.
Right now im working on a modified power supply that car run from the 12V availible from the battery.
What I am a little concerned about are the boot times and shutdown issues with this project.
What would be ideal is an OS which has a quick boot time, but more importantly, does not freak out when power is cut off without shutting down. It must also be able to operate efficiently at fairly low resolutions from the 7" TFT screen
I suppose I could design a circuit which would force the system to shut down triggered by the ignition switch, but that may present some problems with power staying on for some reason or other due to a failed shut down.
If you have any suggestions, dont hesitate to reply.
