Laptop wireless
TheatreTechie
Im thinking of getting a wirelss router and card for my laptop. Should I go with the PCMCIA card or with the UBS for the laptop. I was thinking the UBS so if i decided to scrap the laptop i can use the UBS on the desktop.
If you want mobility then go with the PCMCIA card, if you want to carry around a long cable and 3x3in device then go with USB.
They might make pen drive size USB wireless NICs but I havn't seen any. My advice is go with PCMCIA it's just easier to tote around.
well 3com's got really good stuff, linksys is allright as long as firware upgrading isnt involved. lots of people have trouble after firmware is upgraded. glad I never had to on mine.
