itunes help
weezle69
I just installed itunes and I cant seem to find a tab to tell it what music folder I want to use with it. It just scans my whole computer and puts all the music files in there. I only wantd a certian folder in there. Is there a way to change this setting?
I know this isn't the answer you are looking for but uninstall itunes and install foobar
/thread
I found that but I dont want all my other music in itunes. I'm looking for a way to take the other folders out.
Remove everything from the library (but don't delete the actual files on your system, of course), uncheck the option to let iTunes manage your music, and import just the folder(s) you want.
