Issue with ASUS GPU Tweak 2
Dmac122383
I just got a new ASUS GTX 1080 Turbo video card and having an issue with ASUS Tweak 2 program. There is no option for me to increase the GPU Core Clock, I only have options GPU Boost Clock and the Memory Clock (I do have the other fan, power target, etc options).
I've uninstalled and re installed the program a few times and have been using the latest version. I'm sure I could probably use MSI afterburner or another OC Utility (Haven't tried it other programs yet to see if GPU Core Clock options are there) But I'd really like to use this ASUS App because I like the lay out and how it works.
I did enable the "Overclocking range enhancement" option under Tuning Settings in the options menu. Can anyone tell me why I don't have the GPU Core clock option or what I need to do to be able to adjust the GPU core clock?
Thank you.
EDIT: I just thought that maybe since this video card is kinda of a low end budget card that I do not have the ability to adjust the GPU core clocks? But I've had probably 10 video cards over the years that I've overclocked and dont ever remember not being able to fully overclock the cards.
I also have another question about this card - It says that it has the customization LED ASUS logo and I've tried downloading the ASUS Aura program but it says I dont have an aura card. How do I change the colors of the LED lights and the ASUS logo?
isn't boost clock the same thing as the core clock? maybe try AB.
I think boost clock is the same as core clock. I just wasn't familiar with Nvidia cards and settings. Still can't figure out this Aura/LED issue.
GPU Tweak gave me nothing but problems. (it would drop overclocks at random for seemingly no reason, the app would crash etc)
I switched to Afterburner and installed the EVGA Precision skin to enable Kboost, zero issues. Works great!
