IPCop in VM on host PC
plinx0r
Bottom line is I want to run IPCop in a virtual machine on my main PC which runs VMWare Server. I know this can be done but I'm still trying to piece together exactly how to set up the network settings. I have three NICs and I'm thinking
  1. 1st NIC (Red) to DSL modem
  2. 2nd NIC (Green) to LAN switch
  3. 3rd NIC (Green) to LAN switch
I want NIC 1 to act as the red interface in IPCop. It should interface with my DSL router and pick up an IP from ISPs DHCP. I was thinking NIC 2 will present itself as the gateway to the lan (my home network gateway is 172.27.34.1). NIC 3 would not be configured in VMWare at all and just act as normal DHCP client, picking up a 172.27.34.x IP.
My question is, how do I configure NICs 1 and 2 in VMWare server? Bridged? Host? Nat? Does this make sense?
Any comments would be helpful.
i think you want bridged networking and then in the advanced settings i think you can bind it to a specific virtual adaptor that is then bound to the physical adaptor...
at least thats how i think it works, i would very interested to know this also though! :)
Bridge the red NIC to the to a virtual adapter assigned to the public interface of your host machine. On your host machine, disable all protocols on this interface.
One warning though, there are latency problems with this. I had this running for a little while. Because of the problems, I came up with a new rule for my home network: All firewalls are a to be a dedicated on non-virtual hardware.
hmm. well currently I have ipcop running on an old AMD t-bird box with 768 megs of ram but I want use that box for something else. so if I game this probably wouldn't be the best solution?
I wouldn't recommend it. For a security device such as a firewall, the best solution will always be a dedicated device running the minimum it can to perform its job. Aside from that, there are problems with running such a device virtually. I experience random latency issues, dropped packets, session errors, etc. Just bite the bullet and find an old machine to run it on. You will be happier in the long run.
