Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
It does both infrared and comes with a thermocouple for foods and stuff. Thermoworks is about the best you can buy as well. I have some of their other products and they are very good.
We use those at work for production. These do have a thermocouple as well. Also, with IR guns, the further you are from the target, the wider the spot reading is.
Don't buy a cheap POS, we found that the temps varied wildly. The flukes can also be calibrated which we do in-house as well.
If the flukes are used, find out about the calibration. You can also calibrate it yourself to a known source of heat. I believe you can use ice water with a typical glass thermometer in it.
Man if you just want a couple of quick measurements get a Rosewill from Newegg for $20 on sale. If you need precise measurements for business or something important then get the Fluke. $$$ http://www.newegg.com/Product/Product.aspx?Item=N82E16896268001 -Rosewill - I have one & it works ok.
