Image Rollovers won't work
Tutruk
I have no clue what I'm doing with these rollovers and I'm learning as I go with this... can anyone help? I get no errors.
Code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<script type="text/javascript" src="scripts/scripts.js"></script>
<script language="javascript">
level = 0;
//Preload All Images
if (document.images)
	//Load the button off images
	contactOff = new Image();
	contactOff.src = "images/nav/senior/contact.jpg";
	contactOn = new Image();
	contactOn.src = "images/nav/senior/contact1.jpg";
	aboutOff = new Image();
	aboutOff.src = "images/nav/senior/about.jpg";
	aboutOn = new Image();
	aboutOn.src = "images/nav/senior/about1.jpg";
	copyrightOff = new Image();
	copyrightOff.src = "images/nav/senior/copyright.jpg";
	copyrightOn = new Image();
	copyrightOn.src = "images/nav/senior/copyright1.jpg";
	sourceOff = new Image();
	sourceOff.src = "images/nav/senior/source.jpg";
	sourceOn = new Image();
	sourceOn.src = "images/nav/senior/source1.jpg";
	herfdnOff = new Image();
	herfdnOff.src = "images/nav/senior/herfdn.jpg";
	herfdnOn = new Image();
	herfdnOn.src = "images/nav/senior/herfdn1.jpg";
	homeOff = new Image();
	homeOff.src = "images/nav/senior/home.jpg";
	homeOn = new Image();
	homeOn.src = "images/nav/senior/home1.jpg";
	infoOff = new Image();
	infoOff.src = "images/nav/senior/infomatic1.jpg";
	infoOn = new Image();
	infoOn.src = "images/nav/senior/infomatic.jpg";
	multimediaOff = new Image();
	multimediaOff.src = "images/nav/senior/multimedia1.jpg";
	multimediaOn = new Image();
	multimediaOn.src = "images/nav/senior/multimedia.jpg";
	activitiesOff = new Image();
	activitiesOff.src = "images/nav/senior/activities1.jpg";
	activitiesOn = new Image();
	activitiesOn.src = "images/nav/senior/activities.jpg";
</script>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link href="scripts/style.css" rel="stylesheet" type="text/css">
</head>
<body bgcolor="#B6D3BA" leftmargin="0" topmargin="5" marginwidth="0" marginheight="0">
  <table width="818" border="0" align="center" cellpadding="0" cellspacing="0" id="bottom">
  <tr>
    <td width="168" height="98"><img src="images/nav/senior/home.jpg" alt="Home" name="home" border="0" usemap="#homeMap" id="home" width="168" height="98"></td>
		<td width="131" height="98"><img src="images/nav/senior/about.jpg" name="about" border="0" usemap="#aboutMap" id="about" width="131" height="98" alt="About us"></td>
		<td width="133" height="98"><img src="images/nav/senior/contact.jpg" name="contact" border="0" usemap="#contactMap" id="contact" width="133" height="98" alt="Contact us"></td>
		<td width="123" height="98"><img src="images/nav/senior/copyright.jpg" name="copyright" border="0" usemap="#copyrightMap" id="copyright" width="123" height="98" alt="Copyright"></td>
		<td width="112" height="98"><img src="images/nav/senior/source.jpg" name="source" border="0" usemap="#sourceMap" id="source" width="112" height="98" alt="hwhw"></td>
		<td width="151" height="98"><img src="images/nav/senior/herfdn.jpg" name="herfdn" border="0" usemap="#herfdnMap" id="herfdn" width="151" height="98" alt="ewhwh"></td>
  </tr>
</table>
  <map name="homeMap" id="homeMap">
	<area onMouseOver="Switch('home','homeOn')" onMouseOut="Switch('home','homeOff')" shape="rect" coords="14,27,135,79" href="index.htm" alt="Home"></map>
<map name="copyrightMap">
   <area shape="rect" coords="11,44,95,74" href="copyright.htm" alt="copyright" onMouseOver="Switch('copyright','copyrightOn')" onMouseOut="Switch('copyright','copyrightOff')">
</map>
<map name="aboutMap">
  <area shape="rect" coords="24,40,111,72" href="about.htm" alt="About" onMouseOver="Switch('about','aboutOn')" onMouseOut="Switch('about','aboutOff')">
</map>
<map name="contactMap">
  <area shape="rect" coords="21,43,111,75" href="contact.htm" alt="Contact" onMouseOver="Switch('contact','contactOn')" onMouseOut="Switch('contact','contactOff')">
</map>
  <area shape="rect" coords="2,52,92,83" href="copyright.htm" alt="Copyright" onMouseOver="Switch('copyright','copyrightOn')" onMouseOut="Switch('copyright','copyrightOff')">
</map>
<map name="herfdnMap">
  <area onMouseOver="Switch('herfdn','herfdnOn')" onMouseOut="Switch('herfdn','herfdnOff')" shape="rect" coords="0,6,130,83" href="hehehe.htm" target="_blank">
</map>
<map name="sourceMap">
  <area shape="rect" coords="22,4,95,83" href="ehehe.htm" target="_blank" alt="ehehe" onMouseOver="Switch('source','sourceOn')" onMouseOut="Switch('source','sourceOff')">
</map>
<map name="infoMap">
  <area shape="rect" coords="13,31,155,77" href="infomatic.htm" alt="Infomatics" onMouseOver="Switch('infomatic','infomaticOn')" onMouseOut="Switch('infomatic','infomaticOff')">
</map>
<map name="multimediaMap">
  <area shape="rect" coords="8,31,150,77" href="multimedia.htm" alt="MultiMedia" onMouseOver="Switch('multimedia','multimediaOn')" onMouseOut="Switch('multimedia','multimediaOff')">
</map>
<map name="activitiesMap">
  <area shape="rect" coords="8,31,150,77" href="activities.htm" alt="Activities" onMouseOver="Switch('activities','activitiesOn')" onMouseOut="Switch('activities','activitiesOff')">
</map>
</body>
</html>
EDIT:
I've tried onMouseOver/onMouseOut and was told to change it to onmouseover/onmouseout. Both don't work. All image links are working here (locally, not online). Please ask any other questions.
Here's whats in the scripts.js file
Code:
//function that swaps pictures
function Switch(imgName,imgObjName)
   document.images[imgName].src = eval(imgObjName + ".src");
Dunno, are you sure the path to the .js file is correct? I copied/pasted it here and put the Switch function in the same file as the html and it works fine in Firefox and IE6
Don't use javascript for rollovers. That whole chunk of code could be done with about half that much CSS.
I don't really care, I picked something and went with it.
I fixed the problem... moved the Switch function into the head of the html document
