I need help with a script
Bird222
This is for my tomato router. I am a newb and I have racked my brain for way too long. I am about to pull my hair out. The only error I get is line 73: syntax error: missing '))'. However it doesn't seem to be performing some of the commands that are in the script. Not even a command that is not inside any "if" statements or anything (for example fileDateTor=$(date -r $IPSET_LISTS_DIR/tor.lst +%s). It doesn't add the non-existant iptables rules. This is not my script I am trying to modify it so 1) it doesn't create identical iptables rules if they already exist and 2) update the files and ipsets when they are too old. Also, I could use some help on the "if" section toward the bottom starting with "if [$(($curDate - $(date -r $IPSET_LISTS_DIR/cn.lst +%s)) / 86400) > 5]". I want to check to see if any of the files are older than 5 days and if so download all the files and create the BlockedCountriesNew list, etc. However, I don't want to do the 'swap the list' and 'destroy the list' commands with each loop for each new file. I could not figure out a good way to do that so I came up with the ugly solution below (which may not even work btw). Here is what I have so far.
Code:
#!/bin/sh
blacklist="af cn hk ir kh kp kr kz li my ng ph pk ru sg th ua vn"
# Loading ipset modules "/dev/null 2>&1" says send errors to /dev/null
lsmod | grep "ipt_set" > /dev/null 2>&1 || \
for module in ip_set ip_set_nethash ip_set_iphash ipt_set
do
  insmod $module
done
# "[]" means test whatever is in the brackets Lookup 'test' command for options.
# Preparing folder to cache downloaded files "[-d IPSET_LISTS_DIR]" means test if IPSET_LISTS_DIR is a directory if that fails then run mkdir command
IPSET_LISTS_DIR=/opt/downloads/ipset_lists
[ -d "$IPSET_LISTS_DIR" ] || mkdir -p $IPSET_LISTS_DIR
# Block traffic from Tor nodes "[-e ...]" means test if file exists
if [ "$(ipset --swap TorNodes TorNodes 2>&1 | grep 'Unknown set')" != "" ]
then
  ipset -N TorNodes iphash
  [ -e $IPSET_LISTS_DIR/tor.lst ] || wget -q -O $IPSET_LISTS_DIR/tor.lst http://torstatus.blutmagie.de/ip_list_all.php/Tor_ip_list_ALL.csv
  for IP in $(cat $IPSET_LISTS_DIR/tor.lst)
  do
  ipset -A TorNodes $IP
  done
fi
curDate=$(date +%s)
if [$(($curDate - $fileDateTor) / 86400) > 5]; then
  ipset -N TorNodesNew iphash
  do
  ipset -A TorNodesNew $IP
  done
  ipset --swap TorNodesNew TorNodes
  ipset --destroy TorNodesNew
fi
# "[-z ...]" means test to see if length of string is zero
if [ "$(iptables -nL INPUT | grep TorNodes)" = "" ]
then
  iptables -I INPUT 15 -i vlan2 -m set --set TorNodes src -j DROP
fi
# Block incoming traffic from some countries. cn and pk is for China and Pakistan. See other countries code at http://www.ipdeny.com/ipblocks/
if [ "$(ipset --swap BlockedCountries BlockedCountries 2>&1 | grep 'Unknown set')" != "" ]
then
  ipset -N BlockedCountries nethash
  for country in $blacklist
  do
  [ -e $IPSET_LISTS_DIR/$country.lst ] || wget -q -O $IPSET_LISTS_DIR/$country.lst http://www.ipdeny.com/ipblocks/data/aggregated/$country-aggregated.zone
  for IP in $(cat $IPSET_LISTS_DIR/$country.lst)
  do
  ipset -A BlockedCountries $IP
  done
  done
fi
if [$(($curDate - $(date -r $IPSET_LISTS_DIR/cn.lst +%s)) / 86400) > 5]; then
  ipset -N BlockedCountriesNew nethash
  do
  fileDate=$(date -r $IPSET_LISTS_DIR/$country.lst +%s)
  if [$(($curDate - $fileDate) / 86400) > 5]; then
  fi
  do
  ipset -A BlockedCountriesNew $IP
  done
  done
  ipset --swap BlockedCountriesNew BlockedCountries
  ipset --destroy BlockedCountriesNew
fi
if [ "$(iptables -nL INPUT | grep BlockedCountries)" = "" ]
then
  iptables -I INPUT 15 -i vlan2 -m set --set BlockedCountries src -j DROP
fi
Lines 27 and 62 are missing $ after the first open parenthesis.
Also, 56 has an extra set of parenthesis. Purely aesthetics.
Thanks for the response. Here is the script after I made changes
Code:
#!/bin/sh
do
  insmod $module
done
then
  do
  done
fi
curDate=$(date +%s)
if [$($($curDate - $fileDateTor) / 86400 ) > 5]; then
  do
  done
fi
then
fi
then
  do
  do
  done
  done
fi
if [$($curDate - $(date -r $IPSET_LISTS_DIR/cn.lst +%s)) / 86400 > 5]; then
  do
  if [$($($curDate - $fileDate) / 86400 ) > 5]; then
  fi
  do
  done
  done
fi
then
fi
Now I am getting these errors
Code:
line 36: 1429652599: not found
line 36: /: Permission denied
[: missing ]
In addition, the script seems to freeze there. I had to ctl+c to get back to a prompt. Maybe the numbering is off but in 'vi' line 36 is just 'fi'.
EDIT: Ran the script again and these are the errors
Code:
line 36: 1429653432: not found
[: missing ]
line 72: 1429653432: not found
[: missing ]
Line 72 is another 'fi' also.
Definitely getting closer. The iptables rules are being created now.
I added some variable embeds. Hope that fixes it.
Hard to debug when I can't run it. :)
Code:
#!/bin/sh
do
  insmod $module
done
then
  do
  done
fi
curDate=$(date +%s)
  then
  for IP in $(cat $($IPSET_LISTS_DIR/tor.lst))
  do
  done
fi
then
fi
then
  do
  for IP in $(cat $($IPSET_LISTS_DIR/$country.lst))
  do
  done
  done
fi
if [$($($curDate - $(date -r $IPSET_LISTS_DIR/cn.lst +%s)) / 86400) > 5]
  then
  do
      then
    fi
    do
    done
  done
fi
then
fi
Thanks for the reply. These are the errors I am getting now.
First run. Script froze.
Code:
./asiablock3.sh: line 37: 1429743004: not found
./asiablock3.sh: line 37: /: Permission denied
[: missing ]
./asiablock3.sh: line 55: /opt/downloads/ipset_lists/af.lst: Permission denied
Second run
Code:
./asiablock3.sh: line 37: 1429743077: not found
[: missing ]
date: can't stat '/opt/downloads/ipset_lists/cn.lst': No such file or directory
./asiablock3.sh: line 75: 1429743077: not found
./asiablock3.sh: line 75: /: Permission denied
[: missing ]
Some observations. On second run an identical iptables rule was created unlike the previous version. Neither run created all the $country.lst files Also I think the long number is the 'curDate' if that helps.
I decided to make a small script to test on to focus where the error is. Started with this
Code:
curDate=$(date +%s)
  ipset -N TN iphash
#  wget -q -O $IPSET_LISTS_DIR/tor.lst http://torstatus.blutmagie.de/ip_list_all
#  for IP in $(cat $IPSET_LISTS_DIR/tor.lst)
#  do
#  ipset -A TorNodesNew $IP
#  done
#  ipset --swap TorNodesNew TorNodes
#  ipset --destroy TorNodesNew
fi
Code:
./asia5test.sh: line 13: 1429791747: not found
./asia5test.sh: line 13: /: Permission denied
[: missing ]
BTW that large number is 'curDate'. To me it looks like bash thinks that number is a command. So then I googled 'doing math in bash'. Then I change the script to this
Code:
curDate=$(date +%s)
if [ $(expr $(expr $curDate - $fileDateTor) / 86400 ) > 5]; then
  ipset -N TN iphash
#  do
#  done
fi
Now the only error I get is
Code:
[: missing ]
The problem is definitely in that 'if' statement.
This seems to work
Code:
if [ $(expr $(expr $(expr $curDate - $fileDateTor) + 43200) / 86400 ) -ge 5 ]; then
However this doesn't
Code:
if $(( (($curDate - $fileDateTor + 43200) / 86400 ) >= 5 )); then
Any idea why?
EDIT:
FYI this is the correct syntax btw
Code:
if [ $(( (($curDate - $fileDateTor + 43200) / 86400 ) )) -ge 5 ]; then
