i posted this in displays. but thinking about it, it sorta makes sense to ask this forum too since its an HTPC display thingy.
i just bought a new widescreen 16:9 HDTV. Samsung TX-P2675WHD
im trying to hook it up to my HTPC, but with limited success.
my tv has a DVI cable input. my vid card is a Geforce 6600GT with dual DVI output. im using a DVI cable to connect them. my tv supports 480i, 480p, 720p, and 1080i
i have the most up to date drivers for my video card from nvidia's website.
if i plug my tv by itself into the computers primary dvi out, i get no picture. no picture on the secondary dvi out either.
i can plug my monitor into the primary dvi out and get picture just fine. its actually how its setup right now so i can type to you guys.
if i plug my TV into the secondary dvi port at the same time my monitor is in the primary dvi port my tv works. but the fonts are crazy scrambled, it hurts my eyes just to look at it. if however i plug my tv into the primary dvi out, and my monitor into the secondary out, neither one works..
ok so i plugged it in so it at least shows me pictures on both screens. monitor in primary dvi, tv in secondary dvi.
i played around a bit with it with limited success. i then went searching for an answer online. i found this website: http://www.htpcnews.com/main.php?id=hdguide
at first i was like "YES! this is it", but soon ran into trouble. the guide says to unplug my monitor and plug my tv in its place in several instances. every single time i did i got no picture. the only way i could get a picture is like i said earlier. so i improvised. i kept them both plugged in, set them up as clones of each other and went through the rest of the setup at that page.
it helped, SORTA. it made the fonts easier to read, but no where near good. it would seriously hurt my eyes to look at it for more than a miniut on the tv. the monitor was still good, it just didnt fill the screen cause the resolution wasnt right for it.
so what do i do? how do i get this to work on my PC?
