HTPC build
trick0502
im looking to build a htpc. i was hoping to get this done on the cheap. i was looking into atom (330, 510) but they wont play 1080p so i was kind of against that option. i was thinking a athlon II dual core (maybe unlock to tri or quad) on an 785g mb. i would like to use ddrII because i already have two 1 gb sticks and two 512mb sticks. linux compatibility is a plus because i might try to run myth on it.
htpc
as little as possible
3) Where do you live?
ma, microcenter is about an hour and a half drive (if it will save me i will make the drive)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
cpu, mb ram (maybe), case, tv tuner card, remote
i have 3 gb of ddrII ram i would like to reuse, a ton of old sata hdds, and a dvd-rw
6) Will you be overclocking?
i dont think so, i would unlock a core or two if possible
1080 tv (has hdmi and vga input)
before christmas
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
capture card with remote
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
have win 7 32 and 64, was thinking i would use 32
$59 - AMD Athlon II X2 245 CPU
$70 - Gigabyte GA-MA785GM-US2H AM2+ AMD 785G mATX Motherboard
$60 - XFX HD-555X-ZNF2 HD 5550 512MB PCI-E Video Card
$125 - Hauppauge WinTV-HVR-2250 1229 PCI-E x1 Dual TV Tuner / Encoder w/MCE Remote
$130 - Antec NSK2480 mATX case with Antec Earthwatts 380W PSU
Total: $444 plus tax and shipping.
What exactly did you want to record? Content from your cable TV? Or simply local channels?
Pretty similar to danny's build, just a little tweaking..
70 GIGABYTE GA-MA785GM-US2H
125 Hauppauge WinTV-HVR-2250 1229 PCI-E x1 Dual TV Tuner / Encoder w/MCE Remote
55 XFX HD-545X-YNH2 Radeon HD 5450 (Cedar) 512MB
50 CORSAIR Builder Series CX430
100 SILVERSTONE Black 8.0mm aluminum front panel, 0.8mm SECC body GRANDIA GD04B Micro ATX Media Center / HTPC Case
38 AMD Athlon II X2 Dual-Core Processor 210e Cupon Code COLUMBUS15
451 shipped total
Overall same mobo and tuner, I changed the video card to get a fanless one since most cheapo cards will have loud fans. Changed the Case & PSU to what I think is a better case (and much smaller too) & PSU. Same cost after rebate. Biggest change is to that Athlon II x2 240e.. that is a 45w CPU so it should run nice & cool being in a tiny little htpc & also wont drink quite as much power.
Either build the CPU I listed is a great buy for the use. The rest is just a difference in preference.
Edit: Also 55 in MIR & I believe Danny's build had 35 in MIR if your one of those people who like to take that stuff into account.
Hmm, I would ditch that Corsair and go with this slightly better PSU for the money:
$50 - Antec NEO ECO 400C 400W PSU
Besides that, looks good to me.
not really sure what i would be recording. over the air local would all i would be able to record in hd.
you dont think a 785g (4200) gpu would be enough to do hd? do i really need a discrete gpu?
Ok, then the Tuner card I chose should be fine for that.
The onboard 785G GPU can handle HD once properly setup. Though apparently certain newer HD content, i.e Blu-ray, supposedly requires a dedicated GPU like the HD 5550. Not to mention that the 785G chipset only supports 2.1 audio via HDMI, So if you have a 5.1, 7.1 or other higher end audio setups, the 785G chipset will not do.
good points, thanks for the info. i will not be playing any games on this system so maybe i could get away with a lower end gpu.
also can you unlock any of the cores on the athlon II? i would like to do that if possible.
After rebate the Antec is 23 dollars more then the corsair.. I agree it may be a little better PSU, but not that much better.
Also Consider This Tuner instead and a separate remote. The HD home Run seems to have a better track record for ease of use (this from someone who own's a hauppague 2250)
Now that I think about it, the Antec is the significantly better choice for $23 more:
  • The Antec Neo Eco 400C has 30A on the +12V rail VS 28A for the Corsair 430CX.
  • The Antec has a 3 year warranty VS the two year warranty on the Corsair.
  • The Antec is based on a Seasonic platform known to be capable of providing its rated power at 40C to 50C whereas the Corsair 430CX is based on a CWT platform that's only been shown to be able to provide its rated power at 30C and below.
  • The Corsair's efficiency is only up to 80% whereas the Antec has been certified by 80Plus testing for at least 80% efficiency.
Meh... Either way they are both good PSU's & both more then capable of running the hardware listed & then some with no issues at all. And if you count only the shipped price then the antec is the better choice for sure. For a 23 dollar savings on a 50 dollar item though the performance difference inst enough to justify it IMHO.
Edit: also for the tuner there is a recertified HDHomeRun for 20 bucks less. That puts it cheaper then the HDHomeRun has been selling for on the FS/T forums. Its a good enough buy that I also just ordered one to add to my SageTV server.
5.1 S/PDIF audio outputs through the HDMI port is also available if I am not mistaken.
