Help!!!!
phldbr
Ok, this is probably the dumbest question that some of you may have ever heard. But here it goes: when you have the folders, anywhere ex.: my documents and you click on properties and on the general tab you will see at the bottom "attributes" read-only and hidden. Now, I accidentally chose hidden for one of my folders and they "disappeared". How do I find it again??
Heh, we've all done something similar... Just open Windows Explorer
Tools -> Folder Options -> View -> Show Hidden Files and Folders
That should show you the hidden file as a semi-transparent icon on your desktop.
