crustybooger
- Apr 3, 2004
I've just spent the last two days wiring my house with cat5e and now I'm not sure how to get everything connected together. This is how it is setup right now:
25/25 fiber connection being fed into the basement, from there I ran cat5e to every room in the house. The problem I have is that some bedrooms and the entertainment room require multiple devices to be connected. ie the entertainment room has a PS3, xbox360, apple tv, and a htpc. Then one room has a ps3 and a desktop and so on.
Wireless isn't a option, even with wireless n the best signal I could get was 30%, which was what led me to wire the house in the first place. I've been doing some research and I'm not to sure how to go about it. I currently have a netgear wndr3700 and a dlink Dir-655. From what I've been reading would I be able to just buy a switch, plug that up in the basement. Then place a router thats connected to the switch in the rooms that need multiple connections into those routers?
Thanks!
Thanks!
