Help with Front USB Ports
uNsaiN
I was wondering if you guys could help me hook up my front USB ports to my motherboard. They are USB2.0 wires. I have 2 USB ports in the front. Each of the wires are labeled as follows:
White Wire - Port ( - )
Green Wire - Port ( + )
Black Wire - ( - )
Red Wire - ( + )
In my motherboard manual it has the pins listed as follows:
1 - VCC
2 - VCC
3 - USB0-
4 - USB1-
5 - USB0+
6 - USB1+
7 - GND
8 - GND
9 - (no pin)
10 - USBOC
And thats all it says. Wow, after typing this I think I just figured it out. Tell me if this is right. Red wire to one of the VCC's. Black to GND. White to USB0-. Green to USB0+. And the same with the other four.
Also I have front audio ports, but the wires coming off that are like what you would plug into the audio ports. Are those ment to plug into the back or something?
You are correct!
Not sure on your Audio issue.
some motherboards with onboard audio have headers to plug front panel audio into.
If yours doesnt you might be able to cobble something together to the rear ports, but i wouldnt reccomend it.
