I posted a question in another thread about using Powered Riser Cables. This was answered very quickly
The Problem I have now, from reading different sources, is that I should be using the Molex Connector on the riser cable.
When I hook up the power supplies to the Molex Connecter on the riser cable, using multiple PSU's. I make sure that the PSU that is giving the extra power, is also the same one plugged into the molex.
I don't have to turn on each PSU that is attached, JUST turning on one PSU will auto start the other 2, except for the Main PSU.
Is this normal???????
Do I have bad designed cables?????
Thank Your For Time
In reading And Replying
Thank Your For Time
