headset/microphone question
toga
Hey guys, I have a question.
I currently have a set of headphones (Sony MDR-CD380s) I use for playing games. I am looking into getting a microphone, because I do not have one. A lot of recommendations in these forums call for people to get microphone/headset combinations. This does not work particularly well for me for a couple of reasons not limited to the fact that I rather like my headphones and there is nothing wrong with them. My questions are as follows:
1. Is there a quality difference between a one-piece combo and separate headphones and a microphone? (other than extra wires)
2. Does anyone have a good recommendation for a standalone microphone?
3. I have seen that USB microphones exist. What's the deal? Are they good? Do they suck?
Thanks, in advance for your replies!
-toga
The only thing USB headphones and microphones have is a very slight convenience factor, and that depends on your setup. They cost more, with a small increase on the cpu load. So just get a mic that fits how you want to use it, really about anything except complete junk will be fine for basic voice usage.
Thanks for the reply.
How do i know that a given microphone isn't complete junk?
Most comp mics are fine for voice communications though for professional recording...they will suck. I seriously suggest you look at a combination HS/Mic because it will make life soo much easier for gaming etc. There is no chance you will get feedback or interferrence. I use the logitech set that came with UT2004 CE and it is great...just great.
M
