Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I would say at least the basic analog functions will probably work. I believe though that too much of the DDL functions depend on software drivers to work immediatly in Linux. At the least the driver would require a toggle control to tell the soundcard to switch in DDL which it won't have given that the CMI8738 (the closest matching ALSA supported chipset) doesn't have DDL.
That said it's still worth a try. Good luck & Post your results!
