good setup for HTPC?
Dagatech
I'm trying to stay cheap, but I do want quality. The below comes to $740 total, with a couple things on sale.
Antec NSK2400 (comes with PSU)
Asus M2NPV-VM (6150 chipset so onboard video)
Athlon 64 3000+ (AM2)
Corsair ValueSelect 1gb(2x512) DDR2 533
Seagate 7200.10 320gb
NEC 3550A
nVidia DualTV w/ MCE remote
Windows XP (already have)
GB-PVR
I'll be using this for a standard def tv, doing dvr work and dvd watching. no games. If i ever get to HD, i'd probably just upgrade the pc then. Does this look like a good setup? Would it be worth it to upgrade the processor?
For SD it's plenty fine.
I would add a small, seperate, hard drive for just the OS though. If and when you upgrade it makes it a lot easier to have the OS on it's own hard drive.
What remote?
hmm, thats a good point. I'll see if I can find one lying around somewhere.
I was thinking the MCE remote that comes with the DualTV tuner, but I was just looking around and saw this, which could be a good remote plus gets rid of having an external receiver. profit?
That should work just fine.. I use a skt 754 3000 with 512mb. ram and an ATI 9500 for vid. and mine works well so yours should be too. I second the 2 drives.. or at least 2 partitions. started with just one big drive and the first time I filled the drive up and the system crashed, I changed it quick.
i agree 2 HDDs and if you stream or encode an videos to divx i would suggest an x2 CPU but it looks good
okay, I can take the Seagate 80gb from my computer and make it the OS drive on the htpc. i probably won't be doing any encoding, and anyway even if i do I can just schedule it for overnight, i'm not worried about that.
any thoughts on the M-Play 202? experiences, good or bad?
mplay looks cool. if it was IR learning I wopuld so go for it. If I am spending over $40 for a remote though, I am going with one of the harmony remtoes personally.
I agree that the harmony remotes are nice, but don't you have to have an IR receiver already?
yeah, but you can get an IR receiver for less than $20 on ebay. Easiset thing to do is buy an MCE remote receiver. most of the higher end harmony remotes have a built in code for MCE.
I'm actually looking at a similar system and I had a question about the graphics capablities of this board. Would it be enough to run 1080p well, or would another graphics card be needed for that?
If you're talking about just outputting to that resolution then yes it'll work like that. If you're talking about using VMR9 rendering at that resolution then no you'll want a dedicated video card. The 6150 chipset is best for 720p and 1080i output, 1080p is a bit more demanding.
