Girlfriend build
dawhitewizard
This is for my girlfriend to do college homework on. Should also be able to run ms office, browse the web, and stream netflix. Should have a wifi card for wireless tethering to her phone since she does not have actual internet service. She is not tech savy and all parts should play nice with windows 7 without any effort. hdmi out for hooking up to the tv for streaming would be nice but not a deal breaker since her tablet can stream to her tv.
550 + shipping/tax but the cheaper the better.
San Diego, CA
i really hate fry's but there are a couple close by. I really like newegg but it may be nice to order from amazon or somewhere to avoid tax.
case, psu, mobo, cpu, ram, cd/dvd, hdd, monitor, keyboard, mouse, wifi
n/a
6) Will you be overclocking?
nope
n/a
next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
onboard video and sound would probably be helpful to keep cost down. hdmi out would be nice but not a deal breaker.
win7 64bit
what do you guys think about these parts? notice anything i should stay away from or any ideas to lower the cost?
NZXT Source 210
Antec EarthWatts Green EA-380D Green 380W
BIOSTAR A880G+ AM3
AMD Athlon II X3 455 Rana 3.3GHz
G.SKILL Ripjaws Series 4GB (2 x 2GB) DDR3 1333
Samsung by Seagate Spinpoint F3 HD502HJ/ST500DM005 500GB
ASUS 24X DVD Burner
NETIS WF-2113 Wireless-N Adapter IEEE 802.11b/g/n
ASUS VW224U Black 22"
$535 + shipping/tax
save yourself some time and buy a pre-built. you should be able to get a dell or something similar for less than your budget that can do all of those things.
I really don't think going AMD is a good idea, even for a budget build. Everything else looks okay, but I'd swap out the Athlon II X3 and the BIOSTAR for these:
GIGABYTE GA-H61M-S2H
Intel Pentium G850
Sandy Bridge is just significantly better, even at the low end. That set up would only cost you $10 more for the motherboard, if you don't factor in the rebate. Also, they're WAY more power efficient than the X3, which is important because you're buying a cheap PSU and you don't really want to stress it.
If you need to save $10 on something else, I think you could go a little a cheaper on the ram, since you won't be overclocking and I doubt you'll notice the looser timings on a build like this...
Pareema 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
If gaming were an issue, AMD might have a slight edge due to the Integrated graphics being more optimized for that than HD2000, but the stuff you described should be within what HD2000 can do.
AMD is fine for a budget build. If all that's being done with the rig is homework, surfing the net, email, etc, then you won't see any important differences between AMD and a Sandy Bridge.
