Most prices do not include shipping - it will vary based on your location and speed.
For Sale:
$330 Brand new MSI x800XT Platinum Edition AGP. Bought it from ZZF, flashed to XTPE (520/560), runs 100%. Same exact card, just shipped with a different BIOS.
$52 Seagate 120GB IDE Hard Drive. Brand new sealed. Comes with a 5 year warranty. Bought intending to use as a backup drive, but scored an external the same day.
$30
Coolmax Black 400W power supply. Used for a while without any problems. Very quiet due to the 120mm fan. Black finish so it would look absolutely perfect inside a black case. NewEgg link
$1.50 ea 3 Pin fan extension cable. 25" cable for extending those fans!
$71 shipped Fortron Source 400W Green Power PSU. Features a 120mm fan, dual 12v rails, PCIE (or PEG) power connector, tiny heatsinks due to its high efficiency (it will save you money). Ended up buying a different one that was the color I wanted. The nice thing about efficient PSUs is they dont put out much heat and the upgrade may very well lower your temps. Definately a plus for any Intel system owner.
$65 Compaq 15" LCD. Bought it on eBay hoping to stick it in the side of my case just like the PSOne LCD, but have since decided against it. Includes panel and modded power adapter (for hookup to PSU), but no stand. The best thing about this LCD though is that it uses 5v and 12v (I know the pinout too) so its a cinch to wire into a PSU. You've probably seen cases with LCDs in the side - now do the same for your case! Pictures here Lotsa details here (although somewhat innacurate)
$5 48x12x50 CD-RW drive. Works fine, but a year ago it ruined a CD when it spun up really fast (and CD jumped around in the drive). I stuck it in an external enclosure and it worked perfectly since for burning. Includes user manual, IDE cable, Nero Express.
$25 Envision 710E 17" CRT. Used for ~4 years without and problems. Comes in the retail box. Excellent condition (looks new). WOULD LIKE TO MOVE IT OUT SOON! Until then it will sit in my hallway, blocking 1/2 of my door. Link
$56 Sony PSOne 5" LCD screen. Have one of these because they can be modded and used as a second monitor in your comp. These have since been discontinued and wiped out at stores (got these at TRU). This one I bought used intending to mod it, but ended up getting another one before it arrived. Have quite a few of these. ZERO DEAD PIXELS!
. . . $15 off when you buy these two together!
$25 Used PSOne Console + Games. Bought used. Works great and comes with AC adapter, car adapter, AV cable, analog controller (dual stick), Spryo: Riptor's Rage (jewel), Ape Excape (jewel), Gran Turismo 2, and Who Wants to be a Millionaire (scratched, skips)
$85 PSOne Console and Screen Combo. Bought hoping to keep the LCD and sell the console - didnt happen. Screens are quite rare now and this combo is great for trips. I do believe it has a few dead pixels - will double check.
$60 Sony PSOne 5" LCD screen. Have one of these because they can be modded and used as a second monitor in your comp. These have since been discontinued and wiped out at stores. Have 2 new ones.
$13 ea 256MB PC3200 DDR w/ Heatspreadders. Bought from a friend, have too much RAM on hand. Said it overclocked a bit. Works great. Have 2
$11 ea Fuji 30 Pack DVD-R or DVD+R MIJ Taiyo Yuden. Made in Japan = Taiyo Yuden discs. Brand new sealed in package. Bought at Staples a while back. Have a bunch of this stuff and need to move it. This is a great deal for TY discs!
$10 Norton Internet Security 2003. Have three of these new in CD sleeve. Bought a bunch years ago and was selling them. Have these left. Includes AntiVirus and Personal Firewall. NOTE: These are not OEM CDs, but are 100% identical to the retail CDs. Therefore they can be used for upgrade rebates through Symantec. I just did this with a SystemWorks 2003 CD for an AntiVirus rebate and it worked fine! DOES NOT REQUIRE ACTIVATION LIKE THE NEW VERSIONS DO!
$170 Toshiba e740 PDA. This is a great PDA. One of the best in its series. Has 64MB RAM, 32MB ROM, CF & SD cards slots, internal WiFi, the works. I even have an expansion pack that adds USB and VGA out to this unit! Extra $30 for that. This unit is in great condition and has rarely been used. Screen is in tip-top shape.
$10 Swiftech Socket A water block. Block only. Not sure why I bought this - perhaps to convince me to go water cooling, but I've never used it. I think it uses 1/2" OD tubing while I use 1/2" ID so... Would make a good project block I suppose...
$4 7ml LifeDerma Wrinkle Reducing Serum. 14.7ml sells for $119 Get this at an awesome price. Remove those wrinkles from late night computer squinting!
$10 Far Cry DVD 64-Bit edition. New, never used. Key should be good, CD is defunct (perhaps - two files were 0kb in size and I had an issue when installing)
$8
Brytec 2.5" external enclosure. Fits a 2.5" 9mm (or slimmer) hard drive. Rarely used and when I did it was only the USB->IDE board (not the case)
Rounded Cables -
$2 ea ($5 for set of 2 IDE and 1 FDD)
I have a ton of other stuff from HP color toner to Fuji TY DVD-+R discs. There may be a few bugs with the list since I copied it from a SMF forum, but I think I fixed everything. As far as feedback goes, check out LS.Technology on eBay (where this stuff will end up unless...)
For Sale:
$30
$8
Brytec 2.5" external enclosure. Fits a 2.5" 9mm (or slimmer) hard drive. Rarely used and when I did it was only the USB->IDE board (not the case)Rounded Cables -
- Blue rounded IDE cable. 18", two device, ATA-133, bla bla bla. Works great. Have 2. Identical
- Silver/Clear rounded IDE cable. 18", two device, ATA-133, bla bla bla. Works great. Have 2. Identical
- Silver/Clear rounded FDD cable. 18", works great. Have 1.
