FS: AMD64Mobo+Cpu/waterblocks/Rams/Wireless/Misc
lostpnoiboi
I am again parting out more stuff. Will include more WC "stuff" that I have laying around. I will only ship to USA residents only. As shipping it globally is expensive now days. I live in Boston, MA 02136 and everything will be shipped from here or pick up. Thank you.
*NIB* AquaStar Parts includs GPU + CPU = $40
Never been used GPU and CPU
Will not include pump, resevoir = (defective, broken)
Will include each parts, from brackets to screws
Also include Tubes
http://www.tmobilepictures.com/photos/photo32/94/b0/f2bfa9159e69.jpg?_rh=ce9lxkc8jwd61obknrpjeeqyk
http://www.tmobilepictures.com/photos/photo33/dc/d6/2c955f665633.jpg?_rh=6a0e9f14hej8mlc05lj4scu3a
Copper TDX Block for Athlon64 754/939/940 + SunBeam 4ch controller = $35
Good condition, No Leaks, No Cracks, No rust, Very minor scratchs on the Copper +dye can be easily be fix by sanding/cleaning will not affect cooling.
http://www.tmobilepictures.com/photos/photo34/21/99/13f696feedb7.jpg?_rh=86moh0jq1yduxstra9lvzasie
SunBeam 4ch controller *NIB*
-str8 out fan controller with LED lights indicator
1.http://www.tmobilepictures.com/photos/photo33/7b/de/6ad4358bbb51.jpg?_rh=88o99tnmtz9mjkc101936h5wa
3.http://www.t-mobilepictures.com/photos/photo31/c8/5b/008f5abdbed8.jpg?_rh=1462a8dsnoru2v8lp482fs5tv
*NEW*Hawking Hi-Gain Antenna Corner Wireless 2.4GHz + 1x Multi purpose controller = $25
1.http://www.newegg.com/Product/Product.aspx?Item=N82E16833164110&Tpk=Hawking+Hi-Gain+Corner
2.http://www.superwarehouse.com/Hawking_Hi-Gain_Corner_Wireless_2.4_GHz_Antenna/HAI15SC/p/335653
3.http://www.tmobilepictures.com/photos/photo35/5b/53/5d4fc3352055.jpg?_rh=3qssx52fckkavnfjtx2z5t9uu
4.http://www.tmobilepictures.com/photos/photo31/78/06/6d56a2bb8f91.jpg?_rh=dnpkhk4h7pol1gzj4dw5r3o3u
Never used this Antenna longer than 4hrs because it's only good at the direction it's pointed at. Good use for business, school auditorium, or large halls. Not really made for home unless you want stronger wireless signals outside your house IE: back/front yard.
Cooler Master Musketeer System Dynamic Detector (sound controller,cpu fan controller,temp sensor)
-Reflective Blue L.E.D Display
-Thermal Sensor Cable
-80cm 3-pin to 4-pin molex fan cable
-80cm 3-pin (3 wire) to 3-pin (2 wires) + 3-pin (1 wire) fan cable
-PCI socket with single 3.5mm stereo cable
-Dual 3.5mm stereo plug audio cable
-screw packs
2.http://www.tmobilepictures.com/photos/photo34/35/98/71fb6da07ebf.jpg?_rh=7n8jqtracahm0xzobym2nuu38
*MIX Combo Deal* Wire's/Connectors/Adapters cable/PSU Tester/Heat sinks $15
1x CPU AMD stock s939 *never used*
ATi ARCTIC COOLING 5 Silencer *clean*
FoxConn North Bridge (Copper/Green) *never use*
and perhaps few other more if i find them.
1.http://www.tmobilepictures.com/photos/photo35/3f/e6/4160df36a6b6.jpg?_rh=3pjof3cap5gfkwp5iahcq6p
2.http://www.tmobilepictures.com/photos/photo32/72/10/9bfe49a284a6.jpg?_rh=bph1r8oev4q2nzlwm7br4twod
3.http://www.tmobilepictures.com/photos/photo32/57/f2/fed697b19d47.jpg?_rh=5nj93zjk5bh3afex5a2v6p0b4
Complete Set Thermaltake PSU Adaptor cable for AMD/INTEL ATX 12v PSU *NEW
4-pin-8pin Thermaltake PSU Adaptor cable *NEW
CoolMax Power Supple Tester 24pin *NEW
Assorted mix of 3pin- 4pin wire's *Some sleeved, some not
Assorted mix of shrink tubes from large-mid size, small and big pieces. Two colors Yellow/Blue
USB v2.0/firewire connector (internal)
IDE cables *Sleeved and unsleeved
Floppy cable *sleeved
many other misc
1.http://www.tmobilepictures.com/photos/photo32/c5/50/abeeba436036.jpg?_rh=5p5alo5gs2kvwlcx1qxqz9yxs
2.http://www.t-mobilepictures.com/photos/photo35/44/a0/ecebc5b3c644.jpg?_rh=9fw6sjh2q6w0rp6psh6ktmwkt
3.http://www.t-mobilepictures.com/photos/photo31/06/02/52a744e5f043.jpg?_rh=1q7og9ws6ifo7234f8fw42uf
4.http://www.t-mobilepictures.com/photos/photo35/31/89/4cba0a067d49.jpg?_rh=f3ypgyvcp1a6a4yrcbsbz0zn1
All will be shipped through USPS Priorty Mail 3-5days with Tracking #, and insurance will be at buyer expense . All payment transaction will be used using PayPal. Serious buyers only thank you again =)
heatware= lostpnoiboi
ebay = lostpnoiboi
hi, would you sell the ati silencer 5 by itself? if so, are the screws + spacers, pci cover bracket, backplate, all that crap included? hard to tell from the pic if the mounting stuff is complete. thanks! bump for you.
