Found a cool program called Webmin
duby229
http://www.webmin.com/
Check this out....
It is pretty easy to add or remove modules. And the firewall, router, network config, raid, smart, and net monitoring modules pretty much do exactly what I need. All in a reasonable interface.
Webmin is a very popular program. Many big dedicated server hosts use it.
Yeah webmin is pretty awesome. I haven't used it in a while, but I used to use it a lot a few years ago.
It makes server configuration convienient. But, it's still a good idea to know how to configure things the manual way.
another great thing about webmin is all the 3rd party add-ons you can find for it.
Had a really bad experience with webmin in the late '90s and haven't touched it since. Just make sure you back up the configs it touches...Which is good practice any time a tool touches a config file, but becomes obvious when Webmin eats just about every config it touched.
I figured that one out the hard way. I use Gentoo on my desktop, and etc-update decided to eat my config one day. It was prolly my fault.... I prolly hit one instead of two, or something....
But yeah I have a script that I wrote to backup all of the really important config files.
I use Webmin a bit also, though it's not the main way I deal with config files. It's really nice to set up a quick NFS or Samba share though. Definitely worth having installed, IMO.
Duby229: I had etc-update eat some config files once too. Granted, I was new to Gentoo at the time and didn't pay enough attention to it, so it was likely my fault. I haven't used etc-update for a long time though. cfg-update (which is in portage) is much, much better. It keeps an index of which files have been manually modified, and uses a graphical diff tool so you can update those without breaking things.
being a noob , I use webmin alot for initial setup , but I still find I have to get my hands dirty , so to speak, to get everything up and running like I want
darn those linux permissions! :p
[F]old|[H]ard
I use webmin to setup Samba, because for some reason editing the config file by hand or using SWAT never works for me :mad:
etc-config can be really nasty if users blindly hit "update all without stopping" cos each baselayout brings a fresh start to most of /etc. That's why CONFIG_PROTECT is so important.
Re: Webmin - I must agree with Hemi. It completely ate my Postfix config! :eek: Luckily I do nightly backups and it was a simple case of issuing a restore command. After that I don't trust it. Although I'll admit that its crontab interface is handy.
