First LCD....questions
nitro498
I just got a Samsung 940B. I am using a DVI cable only. Should I also use the Dsub? When I try to play BF2, the initial BF2 name pops up and the game won't load. What are the optimum settings for the monitor setup?
Yes, only use the DVI.
Your monitor doesn't support resolutions above 1280x1024 so if you were playing BF2 before at a higher resolution then that would explain why it's not playing.
