Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I need to clone a 300gb drive over to a 250gb SSD. Is there any free software that can do this? I have a double drive dock I can use for the process. It has a duplicator but only works if the new drive is larger or same size.
If you have access to it, acronis true image will do what you are asking.
Paragon will also do it easily.
Clonezilla on the other hand while completely free, won't go from large disk to small disk easily without some fudging. Not saying you can't do it, but it definitely takes a little more knowhow.
