Does this build sound good?
MrJohnson
BIOSTAR TForce TA780G M2+HP
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138114
AMD Athlon X2 5000+ BE
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103194
mushkin 2GB 240-Pin DDR2 800 (2x)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146773
Asus HD3450 256MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121230
This is going to be a desktop computer for HTPC purposes (with some very light gaming). I didn't want to spend any more money really. I would go with the gigabyte motherboard but it doesn't have a PCI-e 1x slot.
Tell me if yall have better ideas. KTHNX
Wow, I guess I missed it. Changed to the GIGABYTE GA-MA78GM-S2H.
I've been out of the build cycle to long. Can anyone tell me if socket 939/940 coolers are compatible with socket AM2/AM2+ mobos?
I have not see a 754/939 cooler that won't fit on an AM2/+ socket (I am sure there are some). Most should be fine, especially if you were just bringing over another stock AMD cooler. As for the build other than the fact you could probably get away with a X2 4000+ and save $40 or so, it's perfect.
