[size=+2]What sort of [equipment] should I get?[/size]
To make useful recommendations, you need to give proper information.
- Give your budget.
How much are you willing to spend to listen to good sound? You might think this computer hobby is expensive but, the amount you could spend for audio can make what you spent on your new computer look like pennies. However unlike high priced computer gear, quality audio equipment does not really become obsolete. Good gear can give years, even decades of excellent service.- Tell us how and where you might use the equipment.
Do you plan to use your computer audio rig to listen primarily to music, play lots of games, and/or watch movies on your computer? List a few kinds of music, games, and movies you like. Give us the size of the room, and how the speakers and listeners might be placed.- Tell us what other audio equipment you have on hand.
It makes little sense recommending uber-speakers if you plan to run them off some crappy integrated sound implementation. Also, where available, old speakers or receivers might be rolled in to the solution to produce good sound for rather little money.
