Yes. Isn't it a beauty (and power)jojasary said:i love that soo much, it even has a uv kit or something in it to glow under a uv, so it has my three ultimate dreams, nforce4, sli, and uv board. This is socket 939 correct?
DanK said:What's with the 4-pin molex just above the PCIE slots on the DFI?
That makes sense, but I thought PCIE was supposed to supply lots more power than AGP; plus newer videocards hook right into the power supply anyway.Prolly for power from psu to Vid. cards?
Maybe DFI will be the first company to start supporting the use of bigger fanned tornados directly on therir motherboards.
DanK said:That makes sense, but I thought PCIE was supposed to supply lots more power than AGP; plus newer videocards hook right into the power supply anyway.
That made me laugh. (Because it's true!)
I agree, though, it's a very nice board.
MeanieMan said:Asus also uses the plug above the PCI-express slots, its for a more direct and cleaner power to the video cards, so the power doesn't have to travel from one side of the mobo to the other.
centvalny said:I guess no water cooled NB block if using (2) 6800 ultras
