Dell D820
CompilerDude
Hello,
I am going to purchase a laptop. I dont want to spend over 3k. I would like at least a 15.4 inch screen. Below is a laptop I priced out at Dell. Anyone have any experiences with this or would recommend another lappy? Thanx. I will predominantly be using this for coding, compiling, some travel, maybe a bit light gaming..
Latitude D820: Intel® Core™ Duo T2600 (2.16GHz) 667Mhz Dual Core
Genuine Windows® XP Professional, SP2, with media
15.4 inch Wide Screen WUXGA LCD Panel
2.0GB, DDR2-667 SDRAM, 2 DIMMS
512MB NVIDIA® Quadro NVS 120M TurboCache™
100GB Hard Drive, 9.5MM, 7200RPM
Touchpad with UPEK® Fingerprint Reader
Floppy Drive
Dell Wireless® 350 Bluetooth Module
90W A/C Adapter
8X DVD+/-RW w/Roxio Software™ and Cyberlink Power DVD™, no media
Intel® 3945 802.11a/g Dual-Band Mini Card
9 Cell Primary Battery
3 Year Standard Plan (NBD onsite with Gold Tech Support and CompleteCare)
6 Cell Media Bay Battery
D/Dock, Expansion Station
Dell Wireless 5700 Built-in EVDO Mini-Card for Verizon Wireless service
Dell Additional Combination Power Adapter includes Auto/Air and AC
Total: $2,935.59
It doesn't seem anybody owns any of the dell business models, I'm looking into the d620. They look like nice laptops.
I've used both the D620 and D820. Both are very good, I'd recommend the 620 over the 820 based on the weight and portability, but if you have to have a 15 inch screen, go for it. As for the price, seems a little steep, you might want to look around for some coupons or friends that get EPP before purchasing.
I have a D800 (older model of what you are looking at, same formfactor) and it is a great machine. Very solidly build, good keyboard, bright screen, haven't had any reliability problems.
thanx for the replies! I may just pull the trigger and get it..
I am also look at hypersonic-pc: The following is 3k.. I know they are completely differently laptops(this is more for gaming) but I can buy my own memory and the company would pick this up..
* Aviator CX7 Duo: High Performance 17" Centrino Duo Gaming Notebook - Qty: 1
* Aviator CX7 in Silver with Tinted Brushed Aluminum Cover - Qty: 1
* 2.16GHz Intel® Core Duo Processor T2600 / 2MB Cache/ 667MHz FSB - Qty: 1
* Intel® 945PM chipset + ICH7M Mobile Motherboard (CX7-Duo) - Qty: 1
* Nvidia GeForce Go 7900 GTX PCI-Express 256MB GDDR3 - Qty: 1
* 80GB 7200rpm Serial-ATA Hard Drive with NCQ & 8MB Cache - Qty: 1
* 8X DVD ± R/W Drive Dual Layer w/ DVD Recording Software - Qty: 1
* 17" WUXGA 1920x1200 VividView™ Display w/ Super Clear Glossy Surface - Qty: 1
* Built-in High Definition 3D Sound System for CX7 - Qty: 1
* Integrated 10/100/1000 Gigabit Ethernet Controller - Qty: 1
* Internal 802.11A/G 54Mbps Wireless Mini PCI for CX7 - Qty: 1
* Integrated V.92 56K Fax/Data Modem - Qty: 1
* MS Windows XP Home Edition CD & Manual SP2 Pre-Installed & Configured - Qty: 1
* (No Disaster Recovery DVD) - Qty: 1
* 2 Year Accidental Damage Protection (System and LCD) - Qty: 1
* 2 Year Platinum Warranty with 24/7 Toll-Free Tech Support - Qty: 1
