Customizing Common Dialogs help??
croehrl
Does anyone know of a registry entry that can disable cut/copy/paste? I know this is a strange request, but this is what I need:
From any explorer window (specifically, common dialogs) I need to find a way to prevent users from being able to ctrl-x, ctrl-c, and ctrl-v. Preventing file deletes would be nice as well, but isn't mandatory.
I cannot do this through a group policy or by setting permissions. This will be on a stripped-down WinXP build, and these functions will not exist.
I cannot use any of the examples Google turned up, since they are written in VB. The environment I'm using doesn't support VB executables... I can only use non-MFC C/C++ programs, Python, or registry entries. (possible to use .CMD files as well, but it seems unlikely that will help)
I've already found a way to disable the context menu, so that much is safe. I've also found a way to disable specific drives from being viewed, but there are instances where I need to allow the user to see the contents of the drive.
So..... can anybody offer some help?
not sure but u might be able to find it in group policy
start > run > gpedit.msc
*edit.. opps.. spoke to soon
