creating a PXE boot cd
wuzzzy
alright I have tried to create a cd so I can PXE boot and try to grab a image from a RIS server. but the problem is that it's not working when I try to burn a CD of it. I am able to get a floppy working but can't get a CD burnt. I'm using Nero and rfbg.exe to create the floppy. Any help would be great. Thank you in advance.
If you have a floppy drive in the same machine you can just tell Nero to make a bootable CD from a:. Don't use any of the advanced options and it should just work. Should also work if you create the disk image with WinImage. Never heard of rfbg.exe so I can't help you with that.
tried doing that and pointed it to the floppy when i put it in to boot it wouldn't work gave a invalid boot disk.... oh well thanks for the help love the graphics :D
