Hey guys. Over xmas, I performed my first full build - a c2d machine that I've been really happy with - until recently.
e6600 - stock setting atm
asus p5w-dh deluxe
zalman 9500
crucial ballistix DDR2 running at 1069mhz, 5-5-5-15 @ 2.2v
antec P180b
thermaltake toughpower 700w
XFX8800gts
150gig Raptor
Xi-Fi Xtreme Gamer
Lite-On SATA Combo Drive
running winxp sp2
Lately, I've been having a recurring problem, which I believe I've traced to a damaged/faulty processor. Once completely shut down and cooled off, the machine refuses to power up on the first try (sometimes even the second try, third try, et al.). The fans spin, the mobo has power, the hd is working, etc., but my display (NEC 1970gx) reads "no input detected" and remains blank. After a few manual shutdowns/startups, it'll finally 'take', so to speak, and it'll run normally. Normally, that is, until I try running Prime95 -- it always reports an error immediately, regardless of the speed/voltage, and even at stock settings. I've tried removing/reseating RAM and changing the slots I've been using, and that doesn't seem to be the issue.
I've done some poking around on google, and it sounds like the symptoms of a failing processor. Now, I've overclocked the thing, but I've been cautious with it. I've never made huge jumps in frequency or voltage, and at no point were the volts over 1.4 or the cpu temps (at load) over 55c. The max overclock I've taken it to was 3.2ghz, at which point it was passing prime95 for hours on end.
As I'm a broke grad student, I'd really like to RMA the thing back to intel. My finals are over after next wednesday, and I could (probably) go computer free until a replacement arrives. However, having overclocked the thing, I'm wondering what my chances are of even getting a successful RMA in the first place. That's where you guys come in. I'd really appreciate any advice or pointers to smooth through this process as quickly as possible. Additionally, if I've no shot in hell of getting an RMA, I'd like to hear about that too. All suggestions are more than welcome.
Oh, and if I do replace the proc, am I going to need to reinstall windows as well?
Thanks.
asus p5w-dh deluxe
zalman 9500
antec P180b
XFX8800gts
150gig Raptor
Xi-Fi Xtreme Gamer
running winxp sp2
Thanks.
