Hi Guys,
This is kind of unrelated to computers, but the heating issue is something I thought you guys might be able to help out with.
Basically, we have this imaging device, can't say much more because it's something we are developing at work.
But we need to displace about 70W of heat. So we have a Peltier attached to the bottom of a sensor (which generates most of the heat) and then the peltier is connected to the base of a heatsink with heat pipes.
However, we're not able to cool the full 70W that we pump in. And even weirder anomaly is that when we pump in less power, 65W, there is more heat generated.
Any Ideas?
Granted, our heatsink with the heatpipes is oriented upside down. Will that have a major effect? What other problems do you think there might be?
Thanks for your help!
--Rachit
Any Ideas?
--Rachit
