So I've had the itch to build a new system, but no real identifiable need for one. So I figured why not get into mining? I get to build a new system, I get to learn some new things and perhaps I'll even make some money. I plan on just running Nicehash on my 1050TI tonight just to familiarize myself and expand from there.
So what I'd like to do is identify a motherboard that'll allow me to run up to 6 GPU's, although I'd settle for something that can handle 4. Then I'd start out mining with a pair of 1060's or 1070's. Haven't decided yet, but that's what I'm liking budget wise.
It seems a good motherboard is hard to find and/or tricky to identify. I imagine a full-ATX motherboard is a good starting point for slot availability? From there it'd be awesome to get something that needs DDR3 memory, given the current pricing of DDR4 memory. But I'm sure much of those motherboards have been gobbled up/are hard to come by.
So my question is, can you guys make a few suggestions as to what to be on the lookout for and/or if you know of a decent guide as to what to look for? From some google searches it seems the ones to look out for are either motherboards designed for mining or otherwise there are some gaming motherboards that also look like they'd fit the bill.
Beyond that I was planning on a power supply from a reputable manufacturer, such as Seasonic, something gold rated and perhaps around 1000 Watts.
Alternatively I had considered just upgrading the PSU in my gaming rig for now, as I imagine that'd support a couple of 1060's and perhaps even the 1050? Then see where this takes me from there?
