Computer Latency Issues, Need help Please!
Kodin
Hi All
I have been having problems with my pc, I was playing some GTA 3 Def Edition last night when after about 10 mins the audio started cutting out and my frame rate became choppy, I tried GTA 4 and also sleeping dogs and the same thing happened. I downloaded Latency Mon and I we as getting huge latency so i reinstalled windows 10 pro. Now the latency isn't as bad and the sound isn't cutting out but I'm still getting choppy frame rate. For example i played about 8 mins of Lego star wars the Sky Walker Saga even though the sound was fine and it said on the FPS counter I was getting 130 FPS it still felt choppy.
specs below
8700lK @ 4.7 GHz,
Asrock Taichi Z370 Mobo
1080 TI
32 GB of memory
Latency Mon dump after 8 Mins of Lego star wars the Sky Walker Saga
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU
throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:08:16 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-EMM1LMB
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: To Be Filled By O.E.M., To Be Filled By O.E.M.
BIOS: P3.40
CPU: GenuineIntel Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 32691 MB total
CPU SPEED
Reported CPU speed (WMI): 3696 MHz
Reported CPU speed (registry): 3696 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and
execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 2221.60
Average measured interrupt to process latency (µs): 5.605419
Highest measured interrupt to DPC latency (µs): 2211.40
Average measured interrupt to DPC latency (µs): 2.390491
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 73.383658
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.001169
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.001173
ISR count (execution time <250 µs): 104952
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 691.808983
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 582.53 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.048174
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 582.53 , NVIDIA Corporation
Total time spent in DPCs (%) 0.131495
DPC count (execution time <250 µs): 706627
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 118
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk
while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 3942
Hard pagefault count of hardest hit process: 3680
Number of processes hit: 10
PER CPU DATA
CPU 0 Interrupt cycle time (s): 15.506193
CPU 0 ISR highest execution time (µs): 73.383658
CPU 0 ISR total execution time (s): 0.068323
CPU 0 ISR count: 102935
CPU 0 DPC highest execution time (µs): 691.808983
CPU 0 DPC total execution time (s): 7.651763
CPU 0 DPC count: 679123
CPU 1 Interrupt cycle time (s): 0.758158
CPU 1 ISR highest execution time (µs): 4.686147
CPU 1 ISR total execution time (s): 0.001550
CPU 1 ISR count: 1986
CPU 1 DPC highest execution time (µs): 185.694264
CPU 1 DPC total execution time (s): 0.061103
CPU 1 DPC count: 3062
CPU 2 Interrupt cycle time (s): 0.570796
CPU 2 ISR highest execution time (µs): 2.300325
CPU 2 ISR total execution time (s): 0.000039
CPU 2 ISR count: 31
CPU 2 DPC highest execution time (µs): 59.796537
CPU 2 DPC total execution time (s): 0.030613
CPU 2 DPC count: 7251
CPU 3 Interrupt cycle time (s): 0.336580
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 40.843615
CPU 3 DPC total execution time (s): 0.006033
CPU 3 DPC count: 1060
CPU 4 Interrupt cycle time (s): 0.573654
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 82.963745
CPU 4 DPC total execution time (s): 0.023230
CPU 4 DPC count: 4928
CPU 5 Interrupt cycle time (s): 0.338024
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 65.360931
CPU 5 DPC total execution time (s): 0.004466
CPU 5 DPC count: 933
CPU 6 Interrupt cycle time (s): 0.572462
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 80.110390
CPU 6 DPC total execution time (s): 0.013106
CPU 6 DPC count: 2603
CPU 7 Interrupt cycle time (s): 0.409598
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 78.522186
CPU 7 DPC total execution time (s): 0.006679
CPU 7 DPC count: 1182
CPU 8 Interrupt cycle time (s): 0.508699
CPU 8 ISR highest execution time (µs): 0.0
CPU 8 ISR total execution time (s): 0.0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 58.215909
CPU 8 DPC total execution time (s): 0.012274
CPU 8 DPC count: 2224
CPU 9 Interrupt cycle time (s): 0.381862
CPU 9 ISR highest execution time (µs): 0.0
CPU 9 ISR total execution time (s): 0.0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 330.582251
CPU 9 DPC total execution time (s): 0.006461
CPU 9 DPC count: 1086
CPU 10 Interrupt cycle time (s): 0.475415
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 124.988095
CPU 10 DPC total execution time (s): 0.013019
CPU 10 DPC count: 2167
CPU 11 Interrupt cycle time (s): 0.541027
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 107.695346
CPU 11 DPC total execution time (s): 0.007198
CPU 11 DPC count: 1126
This is no beuno... Not sure if the nvidia driver time is ok, but it seemed high. Maybe see if you can find a slightly older version to see if that helps.
Thermals sounds probable, too.
And check event viewer for anything that looks terrible.
It's nothing to do with temps , i cleaned my PC out about 2 months back. Temps are looking fine to me on HW info. How ever please see attached image the top SSD is the one I use for my OS it says it has 54% of life left could this be part of the issue with the NVidia driver latency?
Would i be better off installing windows on one of the 1TB drives?
yes. since you just reloaded, if you have another known good spare drive, try reinstalling on that, even if it is just for testing...
also, if you are reloading, you should disconnect all those extra drives so stupid windows doesnt put the bootloader randomly on to one of them...
  • Car Reflections: This is the primary culprit. Setting this to Cubemap or Planar (High) causes massive FPS drops and stuttering. Change it to Screen or Planar (Low) to eliminate stuttering with minimal visual loss.
  • World Shadow Quality: High settings here significantly impact performance; lowering this can stabilize frame rates.
  • Frame Limiter: The default frame limiter can cause conflicts. Try disabling it in the advanced display settings or capping the FPS manually to 60 FPS via your GPU control panel, as running significantly higher can introduce physics and audio bugs.
  • Enable DX12: Add -dx12 to the game's launch arguments in the Rockstar Launcher or Steam. This forces the newer API, which handles the engine's demands much better than the default DX11, often doubling stability.
  • Update NVIDIA Drivers: Audio cutting out and stuttering are frequently linked to nvlddmkm.sys (NVIDIA driver) latency. Ensure your drivers are updated to the latest 2026 version.
  • Vulkan Alternative: Some users report success using DXVK (a Vulkan translation layer), though this may cause initial stuttering until shaders compile.
  • Power Management: Ensure Windows Power Plan is set to High Performance and that CPU throttling is disabled in the BIOS.
  • Background Processes: High-priority background tasks (network drivers, RGB software) can interrupt the game thread. Closing unnecessary apps is crucial for this older engine.
  • Process Priority: Manually set the game's process priority to High in Task Manager to ensure the OS allocates CPU resources preferentially to GTA III
