There is a led on the motherboard that is supposed to lite up green at 61c to 80c and red over 80c. I brought my cpu temp up to 79c using prime95 and coretemp. The led never lit up. I would say the board is not reading the cpu temp correctly.rgr that
i was reading the temps with gigabytes goofy eztune software
got some real temp 2.7 action going and the temps are now 60-66C full load using prime 95 25.2
would HT make it run hotter or cooler? i do run with ht enabled on all the cores
Real temp 2.7 reads 6c cooler than core temp on my system.
rgr that
