Can't find a case v.Chenming
SoulkeepHL
Preface: I love my old antec cases, the cases that the no longer seem to make (yes, I know, they never made them, it was always chenming industrial mold corp). I've got a couple of 12xx's floating around, I built a few dozen beige box office pc's using 635's, and I've got a beige 6xx as my primary workstation. No goofy windows, no gimmicks, no cheap flimsy plastic, no cheap flimsy steel, just a simple, sturdy case with an excelent fit and finish.
That said, I'm building a new workstation, and want a new (black) 6xx equivalent, which is a Chenming 501. The problem stems from the fact that everyone seems to be out of stock on them for the next month and a half, and I'm thinking of building in the next week or two. Is there an equivalent model that they still OE for someone else?
I know Outpost/Fry's has those cases on sale for free after rebate a LOT, just usually in blue. It's under the Ultra label.
You might want to check out the Chieftech cases, like here at Xoxide.
Xoxide only has the black in the full size server case, but I'm sure if that's the style you're going for, you'll find them elsewhere in the color you want. :)
