Building my First Comp
effect
I'm trying to keep all of this under 900. I already have the monitor, keyboard and mouse. I'm also looking for a case, can someone recommend me one?
Lite-On White 52X32X52 Internal EIDE CD-RW Drive $27.00
Western Digital 80GB 7200RPM SATA $73.00
Kingston 184 Pin 512MB DDR PC-3200 - Retail $80.00
ABIT "KV8-MAX3" K8T800 AMD Socket 754 CPU -RETAIL $139.00
AMD Athlon 64 3000+, 512KB L2 Cache 64-bit Processor - Retail $223.00
CONNECT3D ATI RADEON 9600XT, 128MB DDR $120.00
So far it cost around $700 USD
well i be better of with the AMD64 or should I save more and get the Barton
save and get the barton.
split the RAM into two sticks. try to gnab the low latency corsair stuff, tons more performance.
do you plan on getting RAID and are you sure you want to have a sata hd ?
correct me if i'm wrong, but I think the AMD64 is better then the barton...I have a 2500 XP barton, and it's only 80 bucks when I bought it...unless there's a 64bit version..I don't know, I have not kept up on processors since I bought my 2500 several months ago.
With DVD burning so cheap, opt for a decent DVD burner to go with the CDRW driver your getting.
I would want a larger hard drive too....My 160 gig is almost full, and I just got it like in March or something...but again this is my preference..
Here's what I Think would be cool for the under 900 range. Keep in mind I am somewhat out of the loop when it comes to the latest 64 bit processors and stuff.
ANTEC Black Solution Series ATX Mid-Tower Case with 350W Power Supply, Model "SLK3700-BQE" -RETAIL
$79.00
GIGABYTE "GA-K8NS PRO" nForce3 250 Chipset Motherboard for AMD Socket 754 CPU -RETAIL
$125.00
ATI RADEON 9600XT Video Card, 128MB DDR, 128-bit, DVI/TV-Out, 8X AGP -RETAIL
$165.00
AMD Athlon 64 2800+, 512KB L2 Cache, 64-bit Processor - Retail
$185.00
Crucial 184 Pin 512MB DDR PC-3200 8T - OEM
$89.00
Western Digital 200GB 7200RPM SATA Hard Drive, Model WD2000JD, OEM Drive Only
$131.00
NEC 8X Dual Layer DVD+/-RW Drive, Model ND-2510A SW BLK, OEM
$88.99
This comes out to like $862 and some change....adjust as you see fit.
$79.00
$125.00
$165.00
$185.00
$89.00
$131.00
$88.99
yeah a dvd burner would be nice assuming he burns or will burn dvds
'better' hmmm... well it has higher performance but isn't 'better'... check its price/performance. and honestly by the time 64 bit computing is mainstream the 754 socketed athlons will be a joke.
youll get tons and I mean tons more performance when you switch that ram to some quality 2-2-2-5t ram like corsair's LL stuff.
I don't want to speak poorly of someones financial decision or anything, but I personally think that on a price performance ratio athlon 64's are a joke.
( Don't get me wrong, I have seen how cool the run and that is not a joke by any length of rope )
There really just processors that are marketed to gamers with deep pockets. I think that you would find your money more wisely spent towards your video card and your ram if you went the path of a 2800 barton or so.
if i'll get a better price/perfomance going with the 2800+ barton. Can someone recommend a setup? well, i'm current researching on some socket A motherboard. I'll see if i'll go with amd64 or just the 2800+ barton
i have come up with this setup for a cheaper system.
ENERMAX Silver 10-BAY ATX Mid-Tower Case(Aluminum Front Panel) with 400W Power Supply, Model "CS-EN5171LBFS-S" -RETAIL $55
Western Digital 160GB 7200RPM IDE Hard Drive, Model WD1600JB, OEM Drive Only $99
Corsair XMS Extreme Memory Speed Series, 184 Pin 256MB DDR PC-3200 - OEM $68*2
ASUS "A7N8X-X" nForce2 400 Chipset Motherboard for AMD Socket A CPU -RETAIL $70
AMD Athlon XP 2500+ "Barton", 333 FSB, 512K Cache Processor - Retail $80
SAPPHIRE ATI RADEON 9800SE Video Card, 128MB DDR, 128-bit, DVI/TV-Out, 8X AGP -BULK $134
I got all of this for $574
Is the PSU in the Enermax case any good? Should i chose this over my other AMD64 setup?
i m upgrading my intel setup this summer to an amd setup... its a crappy intel mobo and a 2ghz northwood A... takin that out and building a system for my mom who only needs it for internet and email... then i m getting the NF7-S and a 2500 barton which i would say IMHO, that its the best setup you can get for now for the cheapest
