I don't use the ingame FXAA, I hate the way it makes everything blurry and dull. I have been using this injector with 4xMSAA and BF3 has never looked better.
There's a 1.30 version floating around, I didn't like the color of it, so I stuck with v 1.25. Try it out and see what you think...its the way the game should look IMO.
http://www.enterbf3.com/topic/6929-fxaa-injectorcolour-enhancer/
Yeah I am reduced to a tiny 19" dell trinitron crt from 2000 atm. I had a nice 22" Sony CRT but it is all washed out and then tried my old 37" LCD tv which did ok but ultimately was way too slow for this game.
Hmm. So there really is no way to clear it up entirely? Pretty sure Super sampling would kill fps. I am running all high w/ low effects, no motion blur, 2XMSAA and HBAO at 1280X1024. Game looks good but man alive it can get blurry.
Do you think the color is way different in 1.30 ? something about it didn't look as good as 1.25 IMO.Best utility ever, been using it for awhile. I'm using 1.30 and its even better but some people prefer 1.25 still.
Just in case anyone wants to try 1.3, I prefer the performance version.
http://extreme.pcgameshardware.de/b...field-3-update-danoc1-v1-3-beta-download.html
Its still WAY better than the vanilla BF3 no matter what version you use.
What is the risk of getting banned for using a 3rd party injector?
I find myself not liking the FXAA with this game. At least the in game. It seems blurry. What have you found works best for getting a clear picture? In game or forcing it through NV control panel or ? I just want to get rid of the fuzz.
The ingame Post Processing AA (FXAA) for BF3 is not to my liking as well. I just use 4x Deferred AA (MSAA) with 16x AF, Ultra on everything, no HBAO/SSAO, Blur OFF. The game looks fantastic this way, much more crisp and clear. Even if FXAA is set to 'Low' it's just too much of a distraction for my eyes.
The FXAA Injecter some people like to use in other games is great, but BF3 really doesn't need it in my opinion.
If you do want to use the in-game FXAA, only use it on Low or Medium (I prefer medium). High is too blurry, but medium gives you pretty much the same antialiasing without nearly as much blurring.
Sure it's not just the 30% jump in default FOV?The models were bigger on screen in bc2, and generally easier to see, even when sniping.
Tried the mod and it works well. I am still playing with it though. The performance version seems to work smoothly. With HBAO on the game seems a bit dark. Still playing around with it but I can say that my game jumped back to a dominant level as I led each server I played on for 4 rounds last night. I can see better now for sure. That is bad news b/c if I spot you first, it is not going to end well for you. Sneaky snake ftw!
Oh and I made the sweetest stinger kill on a jet last night on Caspian. From Russian main and the rocket followed forever almost to the other main before it got him. Pretty to see.
So the injector mod does clear and brighten up the game for sure. Still playing with settings but so far it is an improvement.
I suppose you can use the console command to see fps yes? Forgot to try that last night. need to turn msi off too as I think that causes some performance drag with it not working with the mod.
If it's the same injector I've seen, then yes. Look in the settings.h files.Is it possible to run this just for the color adjustments without any FXAA?
