Best thing for playing your X box.dawtips said:i love my x2vga, www.x2vga.com
Best way to go if you want to play Xbox on the PC monitor or a projector.dawtips said:i love my x2vga, www.x2vga.com
NEVERLIFT said:http://www.newegg.com/app/ViewProdu...-122-180&catalog=47&manufactory=BROWSE&depa=0
I always recommend this card. For the money its a steal![]()
Ryokurin said:but its only 20 more dollars for for a hardware based card. http://www.newegg.com/app/ViewProductDesc.asp?description=15-116-308&depa=0 PVR 150s have been spotted around the same price as well.
You don't use MMC with that, all that card comes with is WindowsMCE drivers. If you were to get that card it is assumed that you alittle about it and what programs will work with and anyone that plays with HTPCs know that.NEVERLIFT said:No thanks I dont like ATI's cards and there MMC is terrible for AVI capturing. It always loses audio synch. I recommend ShowShifter, AVI_IO or PowerVCR.
I've seen one like that for PS2's but I don't remember where. I believe The Batman (member here) uses this for that, just another alternative.Bennyb said:Is there anything like this for a ps2... or is it best to just get a card with s-video in?
CrimandEvil said:You don't use MMC with that, all that card comes with is WindowsMCE drivers. If you were to get that card it is assumed that you alittle about it and what programs will work with and anyone that plays with HTPCs know that.It's a good card, I'd love to play with one now.
Your right but this isn't an AIW. It's a hardware encoding card, little difference between it and Huappauge's 250 MCE.NEVERLIFT said:I know about ATI and have tried their AIW series. I dont like them and there are better cards out for the money![]()
IDversusEGO said:you can use just about any quality transcoder. Do you have component output from your ps2?
link for you...
http://www.lik-sang.com/list.php?nav=over&category=219&
IDversusEGO said:I would suggest this more...
http://www.lik-sang.com/info.php?category=219&products_id=3235&
it is multiformat, better resolutions, is 16x9 capable, and should be compatible with all games.
Ryokurin said:Oh, and do not attempt to play games directly through the tuner card. There will be a delay no matter what you do.
