Phil_needs_help
- Apr 6, 2005
got this message after playing a game - BAD_POOL_CALLER
wots this all about???
running windows XP pro
Ranma_Sao said:
Ranma_Sao said:Well it is 64k.I don't believe however that the hardforums allow a file to be uploaded. Can you put it somewhere I can get at it?
Ranma_Sao said:This memory corruption. Are you Overclocking? Have good memory chips? I would run a memory tester.
http://oca.microsoft.com/en/windiag.asp
Ranma_Sao said:maybe. Thermal always makes wierd errors occur.
Ranma_Sao said:Like work.![]()
Ranma_Sao said:Sure, usually that would cause a machine check exception, but it is possible.
Phil_needs_help said:okies, soo i will try this spare power supply i got - its does 45A! yay!
sooo if that don't work, looks like my computer is just rubbish....
Phil_needs_help said:hey it gets better!! had a "Page Fault in Non-Paged Area" error today yay!
still haven't had chance to put that new power pack in....
Ok.Phil_needs_help said:Sorry to be pain, but could i send you another dump file?? this page fault error keeps coming up, just wanted to shed more light on it...
happened when using internet explorer and was just reading text, sooo no fancy graphics...
Ranma_Sao said:
