Another "help me buy RAM" post!
oneshot
Can't decide between these. They are all using the Micron D9 chips I am almost positive. Going into a E6600/eVGA 680i/8800 GTX build, high overclocking in mind on air. Going to be ordering today so any suggestions would be great. (Buffalo is out of stock @ Newegg)
# Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model BL2KIT12864AA804 - Retail
Cas Latency: 4
Heat Spreader: Yes
Timing: 4-4-4-12
Voltage: 2.2V
# Model #: BL2KIT12864AA804
$289
# Patriot eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PDC22G6400LLK - Retail
Cas Latency: 4
Features: EPP (Enhanced Performance Profiles) Ready
Heat Spreader: Yes
Timing: 4-4-4-12
Voltage: 2.2V
# Model #: PDC22G6400LLK
$236 after rebate
# CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - Retail
Cas Latency: 5
Heat Spreader: Yes
Timing: 5-5-5-12
Voltage: 1.9V
# Model #: TWIN2X2048-6400
$224 after rebate
# BUFFALO Firestix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model FSX800D2C-K2G - Retail
Cas Latency: 5
Heat Spreader: Yes
Timing: 5-5-5
Voltage: 2.1V
# Model #: FSX800D2C-K2G
$244
I'd pick either the Patriot or the Crucial. AFAIK, those Corsairs use Elpida chips.
I would get the Crucial since it is definitely going to have Micron chips, and the Buffalo is currently out of stock at the Egg.
I was about to post the same question. Looks like Patriot is the choice at $236 AR.
