Hi all. I think I'm ready for my next upgrade & like my current system, I'm looking for the best bang for buck. My E2180 was a 50.00 CPU.. I had a Q6600 in the same system but I sold it cause at the time, I didn't really see any major gains for gaming. I mostly play Modern Warfare 2 and everything was smooth as silk but Black Ops seems to be pushing too hard and at 2X AA game play is tolerable but I'd rather be at max everything. To make it more confusing, there are issues with the game itself running smooth for even the best systems.
What I have now:
E2180@ 3GHZ
GIGABYTE GA-P35-DS3
4 GB OCZ Platinum
ATI 5770 905/1250
Would I see any noticeable performance from an AMD 3 or 4 core CPU?
Should I consider some cheap MB/CPU combos like the ones at Micro Center?
Should I just throw in another Intel chip?
Do I select a MB that uses DDR2 to keep my existing RAM or is it worth it to go to DDR3? ram is cheap so I'm not necessarily locked into keeping mine as my current system can be handed down the family upgrade chain..
I really did my best to research prior to posting but there are just too many choices and I'm not exactly current with today's hardware...
TIA
What I have now:
E2180@ 3GHZ
GIGABYTE GA-P35-DS3
4 GB OCZ Platinum
ATI 5770 905/1250
TIA
