NEWBE
:( ok i have a question. i went into bios everything was fine set FSB to 200 (400) to see if it would post. It post's saying its a 3200+ and goes to a blaxk screen and does nothing. try to reboot nothing.... Take out CMOS battery twice and nothing happends........ im stuck plz help... thank you
you did say you removed the battery... but did you actually reset the cmos with the jumper?
