Hello Friends,
Maybe some of you may have some insight on some issue I've been encountering.
I have 2 systems:
5900X/X570 Dark Hero/4x16GB DDR4 3600/750W Seasonic, Powercolor 6600XT Red Devil, 2x 1080p 144hz monitor
5800X/X570 E Gaming/2x16GB DDR4 3600/650W Seasonic, Asus 6600XT Dual, 1x 1080p 144hz monitor
Problem has persisted over multiple BIOS versions but both machines are currently on the latest BIOS as of today, REBAR was always on. Both running Windows 11 23H2. Drivers are exactly the same. I used to undervolt and overclock the memory on both cards via the AMD driver but have since reverted to stock.
To cut the story short, my powercolor refuses to work in the 5900X system but boots properly in the 5800x system.
With the 5900X, Windows will crash and not load, black screen on the desktop and stop working, or will boot but will not properly detect the GPU, with no GPU showing up in the task manager.
With the very same driver, and no driver reinstall, the Asus 6600XT powers up properly on the 5900X machine with no problem. Swapping the powercolor back in results in the problems going back. I was ready to ditch the powercolor and sell it for $20 as defective, but tried on a whim to plug it in the other system, where it proceeds to power on and run properly. Again, no driver update needed.
Right now, I'm perfectly happy with my current solution of just swapping GPUs between systems to keep them both happy... but what would you guys think is the problem is caused by?
Thanks!
I have 2 systems:
Thanks!
