I have an issue where the monitor gets stuck in power save mode on boot. If any had this problem and fixed it, could you enlighten me with a solution. Thanks!
Steps to re-produce:
I am using Windows Vista.
1. Keep monitor turned off (ie amber or blue LED light is OFF)
2. Computer is plugged into DVI-D 1 input
3. Boot Computer and wait the normal amount of time to get into your login screen (I wait about 30s to a 1min to be safe)
4. Turn on monitor
At this point, the monitor looks like it's going to switch the picture on but fails and says power saving mode--ARRGH!
4. Turn on monitor
