Seems that I have to run 1.367v for stability at 4.6 and 4.7 fails even at 1.5v so WTF ?!?!. There was a report that a bios update caused the need for more cpu voltage at the same clock speeds. Is this voltage about on base on above. When I run PRime the voltage in cpu-z hits 1.401. Temps are not an issue as I have a hyper 212 and it does a great job. What am I mssing ? Pll overvolt is on. There are these min max watt settings and miutiplier settings per core in the bios that I dont see mention in any oc guides I have read so nu clue there. I read over and over to leave the intel speedstep and power crap on which I have done. Cpu idles at 1.6 but voltage does not drop. Vdropp is not an issue.
MSI p67 gd55 1.8b7 bios
4 gig ripjaws 9-9-9-24 at stock speed 1.54v
